ryan125hst
Jan 30, 2025Aspirant
Netgear Nighthawk IOT Network?
The Orbi 970 WiFi 7 Mesh Router information mentions that, in addition to a Home network and a Guest network, it has an IOT network. This router is overkill for my house and therefore I was wondering...
- Jan 31, 2025
Due to that Smart Connect can be disabled on the NH routers, there is no separate IoT network.
Jan 31, 2025Guru - Experienced User
- ryan125hstFeb 01, 2025Aspirant
That's a shame as I was hoping to use Smart Connect for the main network and then have a separate IOT network on 2.4 Ghz.
