steveredvan
Jan 15, 2025Aspirant
Netgear Nighthawk RS300
Hi can anybody help I have tried Netgear support and they can’t fix my issue, I have just taken out my BT Home Hub2 router and replaced with a Netgear Nighthawk RS300 Firmware Version V1.0.1.60, I ha...
- Jan 17, 2025
By jove Furrye38 you have cracked my router problem so well done and a big thank you 😊
Jan 15, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers web page? Under Advanced Tab/Administration/Security. If so, disable this feature, apply the change and reboot the router.
steveredvan
Nokia Model Unknown as I said it has all worked OK with BT Home Hub 2 router
I have disabled Protection Engine
I will let you know after 08:30 UK time if the laptop kept the internet connected
Many Thanks Furrye38
