steveredvan
Jan 15, 2025Aspirant
Netgear Nighthawk RS300
Hi can anybody help I have tried Netgear support and they can’t fix my issue, I have just taken out my BT Home Hub2 router and replaced with a Netgear Nighthawk RS300 Firmware Version V1.0.1.60, I ha...
- Jan 17, 2025
By jove Furrye38 you have cracked my router problem so well done and a big thank you 😊
steveredvan
Nokia Model Unknown as I said it has all worked OK with BT Home Hub 2 router
I have disabled Protection Engine
I will let you know after 08:30 UK time if the laptop kept the internet connected
Many Thanks Furrye38
steveredvan
Jan 16, 2025Aspirant
Hi Furrye38, 08:30 my time has come & gone and I have not lost internet on my laptop you may have cracked it 🙂 I will wait until tomorrows 08:30 has come and gone to check all is still well. Many thanks in advance.
- steveredvanJan 17, 2025Aspirant
- FURRYe38Jan 17, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
