ipg8x
Sep 17, 2024Guide
Netgear release MLO support for RS700
Hi Netgear Team, It has been a long wait, waiting for MLO support on Nighthawk R700. I bought the router with impression of using Wifi 7, however to find out MLO is still in works. It has been w...
DarrenM
Dec 03, 2024Sr. NETGEAR Moderator
Multi-Link Operation (MLO) is an advanced WiFi 7 feature that allows your devices to use multiple WiFi bands simultaneously, providing improved performance and reliability. To take advantage of MLO, both your WiFi 7 router and compatible devices must support this feature.
We’re actively working on a firmware update to enable MLO on the RS700 router. As soon as the update is ready, we will share all the details here. We sincerely appreciate your patience as we strive to enhance your WiFi experience.
Thank you for being a NETGEAR customer.
DarrenM
