grasshopper1969
Feb 08, 2025Apprentice
Netgear RS600 firmware 1.0.1.74 query
Hey, just downloaded the latest Netgear RS600 Firmware 1.0.1.74 and when unzipped states its a RS500.bin. Is this just a typo, or wrong firmware posted and its actually for the RS500? thanks
- Feb 10, 2025
Just tested, latest RS600 firmware 1.0.1.74 and looks like this has fixed all my issues running separate SSID's also has fixed my soft reboot issue as well, so very happy now, cheers.
grasshopper1969
Feb 10, 2025Apprentice
Thanks, looks like it has been sorted now, correct file name shows when unzipped, will give this a try see if it corrects separate SSID's loaded, will show them up on network, otherwise will stick to 1.0.1.42 for time being.
Feb 10, 2025Guru - Experienced User
- grasshopper1969Feb 10, 2025Apprentice
- FURRYe38Feb 10, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
