grasshopper1969
Feb 08, 2025Apprentice
Netgear RS600 firmware 1.0.1.74 query
Hey, just downloaded the latest Netgear RS600 Firmware 1.0.1.74 and when unzipped states its a RS500.bin. Is this just a typo, or wrong firmware posted and its actually for the RS500? thanks
- Feb 10, 2025
Just tested, latest RS600 firmware 1.0.1.74 and looks like this has fixed all my issues running separate SSID's also has fixed my soft reboot issue as well, so very happy now, cheers.
Feb 10, 2025Guru - Experienced User
grasshopper1969
Feb 10, 2025Apprentice
- FURRYe38Feb 10, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
