grasshopper1969
Apr 14, 2025Guide
Netgear RS600 internet stalled over 3-5 week uptime
Hi everyone, I'm seeing an issue over time usually every 3-5 weeks of uptime with my RS600, this issue may not be a RS600 issue as it could be an ONT issue but I doubt it the way it behaves after RS6...
grasshopper1969
Apr 14, 2025Guide
Thanks for the reply, the issue is once RS600 reconnects from a dropout, I'm guessing from ISP or ONT it appears that is only runs for a minute then internet connection stops, has no traffic throughput and unable to receive or send data until a full reboot is done yet specs say its all connected & good still at the time of original dropout & re-connect.
Apr 14, 2025Guru - Experienced User
The WAN port and RS would be reporting this event and thus resetting the uptime.
I'd contact the ISP and have then look at the interface device and look at the timeframes when this happens that you see this and see if there is anything they can help with...
