GWTechTalk
Jan 12, 2025Tutor
Netgear RS600 MLO non-Functional
I selected the RS700 above because RS600 was not in the list. First, not to be a negative nelly but the GUI is missing a lot of UI features when compared to other router manufactures. Wish I had r...
Jan 12, 2025Guru - Experienced User
Not all features are the same between router Mfrs. Don't have to be the same. Mfrs set the features to what they want in there products. Up to users to do research on new products before buying.
MLO has not been implemented on the RS series as of yet. In the works from what NG has said. No idea when that will be seen.
Speed results depend on wifi device support and design as well. 2x2 MIMO devices will be limiting. 4x4 MIMO will have better results.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
