itsrobinhood
Oct 19, 2024Follower
Netgear RS700 Wi-Fi keeps dropping randomly
Hello, I purchased a new Nighthawk RS700 in June 2024. The Wi-Fi will keep dropping randomly throughout the week. Every-time it happens, my wired internet thats connected to the a Bell modem still works so its definitely something with the router.
I’ve tried to reset to factory, configure in AP mode, updated to latest firmware V.1.0.7.86 but the issue still persists. My old Asus Router never had this problem. Im tempted to switch back…
If you have any suggestions how I can fix this please let me know.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any other WiFi signal devices near by?
How many devices do you have connected to the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message- dinosworldAspirant
This is silly, my wifes Iphone 15 Pro and sons Iphone 16 max pro have no issues but my iphone 15 max pro wont hold onto the wifi network and requires me to put in my password every single time. I see the orbi had the same issues and they got a firmware update.
What iOS is loaded on these phones?
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messagePlease give feedback to the questions presented.
I have a iPhone 12 Pro Max and it doesn't ask me for the PW.
Try the forget this network for the RS SSID, then try to connect again on your iPhone 15.
