olegeezer
Feb 03, 2025Guide
netgear RS700S router and 320MHz
Hello. I have the RS700S router. I have intel Killer BE1750xw wifi card capable of handling 320MHz. I have searched my RS700S router in 192.168.1.1 for an area that I can set it to 320Mhz. Does any...
Feb 03, 2025Guru - Experienced User
Not sure if this is supported on the RS series currently?
- olegeezerFeb 03, 2025Guide
Hello. In the RS700S manual, it lists the 320MHz but I cannot find any area in 192.168.1.1 where I can select the 320MHz.
With the RS700S being Wifi 7 capable, it should handle 320MHz. This RS700S has out-performed all my expectations. I don't understand why netgear has not provided for selecting the 320MHz.
Thanks, Matt
- FURRYe38Feb 03, 2025Guru - Experienced User
What happens if you disable Smart Connect and check the Up To Speed seen on the RS web page under Basic tab/wireless settings?
- plemansFeb 04, 2025Guru - Experienced User
I don't have the RS700 but with the other devices, you set your channel bandwidth with the "up to ****mbps" speeds
what do you have your set for?
