Oct 28, 2024Guru - Experienced User
New - RS150, RS280, RS300, RS500 and RS600 firmware Version 1.0.1.60 Released
Enhancements: 10/23/2024
Fixes multiple other minor bugs
Adds Advanced Router Protection function. (RS300, RS500 and RS600 series only.)
Download Links:
RS150: https://kb.netgear...
- Dec 05, 2024
Turn it OFF.
matemik
Dec 03, 2024Tutor
Since update V1.0.1.60, whenever i restart the router, i can't get any WiFi working in any band.
In order to get it working properly i need to acces the interface via browser and disable, then re enable vlan/bridge at every power cycle (my ISP do require it to get the connection working). Everything was working perfectly with the older firmware 1.0.0.38.
- FURRYe38Dec 03, 2024Guru - Experienced User
