Oct 28, 2024Guru - Experienced User
New - RS150, RS280, RS300, RS500 and RS600 firmware Version 1.0.1.60 Released
Enhancements: 10/23/2024
Fixes multiple other minor bugs
Adds Advanced Router Protection function. (RS300, RS500 and RS600 series only.)
Download Links:
RS150: https://kb.netgear...
- Dec 05, 2024
Turn it OFF.
matemik
Dec 03, 2024Tutor
It worked flawlessly for months with the old firmware. But i won't rollback to the older version and loose at least another one hour of my time to reconfigure it properly on my network because Netgear is unable to release a non buggy software for a router that costs more than 300€. I'm waiting for a bugfix, by mi research I'm not the only one with that issue. I'm pretty disappointed.
- FURRYe38Dec 03, 2024Guru - Experienced User
You'll need to contact NG support and let them know what your seeing then.
Good Luck.- matemikDec 03, 2024Tutor
I tought that this forum was some kind of official way to report a bug. Thanks for you help.
This is what I get wen i try to open the support contact page.
