Oct 28, 2024Guru - Experienced User
New - RS150, RS280, RS300, RS500 and RS600 firmware Version 1.0.1.60 Released
Enhancements: 10/23/2024
Fixes multiple other minor bugs
Adds Advanced Router Protection function. (RS300, RS500 and RS600 series only.)
Download Links:
RS150: https://kb.netgear...
- Dec 05, 2024
Turn it OFF.
matemik
Dec 03, 2024Tutor
I can confirm that i'm having the first issue you reported. After reboot internet connection on wan port works, wired ports works fine but no wifi radio (even if it is enabled) until i turn off and than back on th VLan tag. But for me the issue appeared only yesterday when i upgraded to the latest Firmware.
BH_C
Dec 03, 2024NETGEAR Expert
Hi matemik, I've sent you the link for the tiral firmware with the fix. Thanks.
- kadmus11Dec 04, 2024Star
Hi, does this trial firmware fix the issue where suddenly every webpage throws up a DNS error, requiring a reboot, until the next time?
- BH_CDec 04, 2024NETGEAR Expert
I don't think so... That is a new symptom first time I've heard.
Did it happen after the FW upgrade to v1.0.1.60? and the old firmware never showed this issue?
Thanks.
- kadmus11Dec 05, 2024Star
Yes, it's since the last firmware upgrade and only seems to apply to windows pc's (in my experience). I have seen others mention this issue on these forums which made me realise that it might be a router issue, and not a windows issue.
- JaJacekDec 05, 2024Aspirant
Can I ask for this link?
- thel0vebel0wDec 09, 2024TutorMay I please have this trail firmware. I’m also experiencing this no WiFi after restarting the device on my RS600. I thought the modem was done after a restart this morning
- BH_CDec 09, 2024NETGEAR Expert
thel0vebel0w wrote:
May I please have this trail firmware. I’m also experiencing this no WiFi after restarting the device on my RS600. I thought the modem was done after a restart this morningWe don't have the trial firmware for RS600 yet. We will need to build one, run it through some basic tests, and then I will PM you the trial firmware. Thanks.
- thel0vebel0wDec 12, 2024Tutor
Thank you I will keep an eye out for the PM.
