Feb 10, 2025Guru - Experienced User
New - RS500/RS600 Firmware Version 1.0.1.74 Released
Bug Fixes: 02/06/2025
- Fixed various bugs.
Download Links:
RS500: https://www.netgear.com/support/product/rs500/#download
RS600: https://www.netgear.com/support/product/rs600/#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a >factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
This article applies to:
Let us know how it works for you...
Updated my RS600 yesterday. Will let it run and observe.
Installed FW, Factory reset and setup from scratch.
PE Enabled.
All other features disabled.
BE200 PCIe cards connecting and reporting on router at 6Ghz.
Connected to a CAX30 in modem mode.
This FW version also includes the RS150 and RS200 models:
RS150 Download:
https://www.netgear.com/support/product/rs150/#download
RS200 Download:
