Dec 26, 2023Guru - Experienced User
New - RS700S Firmware Version 1.0.7.82 Released
New changes: 12/22/2023
Android 14 clients IoT behavior enhancement.
CBP mechanism enhancement.
5G ACS mechanism enhancement.
Bug Fixes:
Fixes case of new SSID change doesn't take eff...
- Apr 19, 2024
New FW released:
Enjoy.
ShadowMario3
Dec 26, 2023Luminary
Unfortunately, this firmware still has the issue with the false positive DoS attacks filling up the logs. Will hang on to the old firmware until this gets fixed.
What happens if you disable the logging feature for DDoS attackes while v.82 FW is loaded?
Also how was the FW updated and did you continue to use the router after FW was applied, powered OFF the router for 1 minute then back ON or had a factory reset been performed afterwards then setup from scratch?
