Dec 26, 2023Guru - Experienced User
New - RS700S Firmware Version 1.0.7.82 Released
New changes: 12/22/2023
Android 14 clients IoT behavior enhancement.
CBP mechanism enhancement.
5G ACS mechanism enhancement.
Bug Fixes:
Fixes case of new SSID change doesn't take eff...
- Apr 19, 2024
New FW released:
Enjoy.
What happens if you disable the logging feature for DDoS attackes while v.82 FW is loaded?
Also how was the FW updated and did you continue to use the router after FW was applied, powered OFF the router for 1 minute then back ON or had a factory reset been performed afterwards then setup from scratch?
ShadowMario3
Dec 26, 2023Luminary
Even when I had logging for DoS attacks disabled, it would still take up resources. Only reason I noticed this was because I noticed that the router was slowing down/crashed by the end of the week. Also, if you turned logging back on, all the previous false positive DoS attack logs would appear right away and crash access to the log itself due to so many entries appearing there.
