Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
ShadowMario3
Apr 19, 2024Luminary
Glad to see that this fixes the DDoS false positive issue. Support sent me a test firmware fix a while back which worked out. Man issue from before was they kept on appearing every 10 seconds and now, they are basically gone.
