Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
FattiesGoneWild
Apr 19, 2024Guide
Checked for update in Nighthawk app and nothing yet. If any update needed to be pushed out automatically quickly, it’s definitely this one. Common Netgear….
If you don't see it via Auto Update, then manually load it. Reason why there is the FW file.
NG may not be auto pushing this one.
