Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
If you don't see it via Auto Update, then manually load it. Reason why there is the FW file.
NG may not be auto pushing this one.
FattiesGoneWild
Apr 19, 2024Guide
Ridiculous. Should not have to do that and needs to be rolled out via Nighthawk app.
- FURRYe38Apr 19, 2024Guru - Experienced User
Feel free to contact NG support and let them know then.
Good Luck.- FattiesGoneWildApr 19, 2024GuideIf I did manually update, can I do it over WiFi? Or does it have to be ethernet?
If you have a good wifi connection and close to the router, yes.
