Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
Feel free to contact NG support and let them know then.
Good Luck.
FattiesGoneWild
Apr 19, 2024Guide
If I did manually update, can I do it over WiFi? Or does it have to be ethernet?
- FURRYe38Apr 19, 2024Guru - Experienced User
If you have a good wifi connection and close to the router, yes.
- FattiesGoneWildApr 19, 2024GuideI went ahead and manually updated over WiFi just fine using my iPhone.
