Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
baforer1954
May 23, 2024Guide
This update negatively affected my throughput. With 1.0.7.82 I got 580 mbps download and 510 mbps upload. After the update I got 250 mbps download and 1 Mbps upload. Reverted back to 1.0.7.82 and all is fine.
ShadowMario3
May 24, 2024Luminary
baforer1954I have noticed this as well, but it's not as drastic of a decrease for me. Before the update, my speedtests were consistently around 2.1 gbps for both download and upload, but after the update, it seems to hover around 1980 Mbps for both.
Unfortunately, I am unable to revert back to an older firmware whatsoever. Don't know if that means my router is bricked or not. Will try to see if a factory reset helps with reverting the firmware.
