Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
baforer1954
May 23, 2024Guide
This update negatively affected my throughput. With 1.0.7.82 I got 580 mbps download and 510 mbps upload. After the update I got 250 mbps download and 1 Mbps upload. Reverted back to 1.0.7.82 and all is fine.
May 24, 2024Guru - Experienced User
baforer1954 ShadowMario3 Has a factory reset and setup from scratch been performed to check this?
- ShadowMario3May 24, 2024Luminary
FURRYe38Just performed a factory reset and noticed that speeds were back up to normal.Once I restored my original settings, a speedtest dipped back down again. Decided to turn off QoS, and that brought speeds back up to normal, so you might want to try that out baforer1954.
Still can't downgrade to an older firmware, so I will need to reach out directly to support about this. I guess it won't be too big of a deal until the next firmware update is released.
- FURRYe38May 25, 2024Guru - Experienced User
I would FR and setup from scratch and no load any prior back up configuration files that were made on older versions of FW. Make a new back up config file. Maybe introducing issues due to changes in newer versions of FW. See this before.
- ShadowMario3May 25, 2024Luminary
I tried downgrading the firmware the moment I did a factory reset, and still no luck unfortunately. Only hope is seeing if upgrading to a higher firmware in the future will work out.
