Apr 19, 2024Guru - Experienced User
New - RS700S Firmware Version 1.0.7.86 Released
Enhancement: 04/16/2024
Support Singapore region in APS
Bug Fixes:
Fixes DHCP IP assignment issue and add option 60/61 for Europe region
Fixes DDoS attack with TCP SYNC flooding.
Fixe...
May 28, 2024Guru - Experienced User
Upgrading to newer FW may still need a FR and setup from scratch and then make a new back up. There maybe changes behind the scenes that cause problems with older backup files that get loaded.
baforer1954
Jul 23, 2024Guide
Just setup an RS700S for my daughters fiber connection and she is having the a similar issue. Her upload speeds a low single digit upload speeds. We both have Nokia ONTs but hers is a 1 gbps version and mine is a 10 gbps version. No one else seems to be complaining about this issue. We cannot run the 1.0.7.86 version and have to use the 1.0.7.82 firmware version
- FURRYe38Jul 23, 2024Guru - Experienced User
So v.82 solves the speed problem for you?
baforer1954 wrote:
Just setup an RS700S for my daughters fiber connection and she is having the a similar issue. Her upload speeds a low single digit upload speeds. We both have Nokia ONTs but hers is a 1 gbps version and mine is a 10 gbps version. No one else seems to be complaining about this issue. We cannot run the 1.0.7.86 version and have to use the 1.0.7.82 firmware version - baforer1954Jul 23, 2024GuideYes, no problems with version 1.0.7.82
- ShadowMario3Jul 23, 2024Luminary
baforer1954Did you ever try disabling QoS to see if that fixed the issue? Doing that fixed the issue for me.
- baforer1954Jul 23, 2024GuideYes, I tried disabling QOSand it did not help
- baforer1954Jul 23, 2024GuideMy ONT is a 10 gbps Nokia, but just realized that my daughter’s was changed from a Nokia to some other ONT that doesn’t have the brand showing on the outside. Neither work with firmware v.86 but both do with v.82
