bd73com
Sep 22, 2025Aspirant
NH RS300 - QoS
Does the RS300 have a QoS feature? According to the manual for the RS300 I have access to there should be a QoS feature in the router. This is a screenshot of the manual, page 104. I the...
Sep 22, 2025Guru - Experienced User
bd73com wrote:According to the manual for the RS300 I have access to there should be a QoS feature in the router.
Odd, that is not the manual I am seeing here:
That page in the version I see is in the uPNP section, and there is no reference to QOS
Can you give some details on what problem you are needing to solve?
