bd73com
Sep 22, 2025Aspirant
NH RS300 - QoS
Does the RS300 have a QoS feature? According to the manual for the RS300 I have access to there should be a QoS feature in the router. This is a screenshot of the manual, page 104. I the...
Sep 23, 2025Guru - Experienced User
Concrete is very excellent at blocking wifi. Probably doesn't help the situation either.
Do you have coax ran throughout the home?
MoCa adapters are pretty great and could be a solution.
Of if you own it and plan on being there a while, getting out the old cement bit and drilling a hole through to run an ethernet wire and hardwiring in the extender.
