RedThunder
May 24, 2025Tutor
NIGHTHAWK D7000 AC1900 to a NIGHTHAWK BE9300 RS300 then the Internet ?
Hi All,9196 I just bought a RS300 Wifi 7 Router and then realised it doed not have a modem in it Doh!. However, I still want the Router but dont really want to buy a modem when I have the D7000 A...
- May 24, 2025
Well I tried your first suggestion above..... AND IT WORKED :-))))
So for the record.
WIFI om D7000 AC1900 (Button on the top, press and hold)
On the RS300. Set as Acess Point, Ethernet from Yellow box on RS300 to D7000 port LAN port 1 (also yellow).
*Side Note.
I have a range TP LINK extender AV600 moved its ethernet to Lan 4 on the RS300, that has just worked like magic :-)
May 24, 2025Guru - Experienced User
You have 2 options.
- leave the D7000 in router mode, disable its wireless, and connect the RS300 to it with the RS300 in access point mode
- Put the D7000 is modem only mode and troubleshoot your connection issue with it. Usually when its in modem only mode, it has a different IP address. When I was messing with my parents DM200, in its modem only mode, its IP address was 192.168.5.1 but you could only access it if it was a PC directly connected to the dm200 and not through a router. I'm not a big dsl guy. I'd recommend checking the forums with prior people who've setup dsl connections via modem only mode. Here's one for example with how someone got it working with the d7000 and a MR60. https://community.netgear.com/discussions/home-dsl-modems-routers/trouble-using-d7000-in-modem/2233148/replies/2235306
- RedThunderMay 24, 2025Tutor
Thanks. I will try that later, or tomorrow morning and report back. Fingers crossed. RT
