RedThunder
May 24, 2025Tutor
NIGHTHAWK D7000 AC1900 to a NIGHTHAWK BE9300 RS300 then the Internet ?
Hi All,9196 I just bought a RS300 Wifi 7 Router and then realised it doed not have a modem in it Doh!. However, I still want the Router but dont really want to buy a modem when I have the D7000 A...
- May 24, 2025
Well I tried your first suggestion above..... AND IT WORKED :-))))
So for the record.
WIFI om D7000 AC1900 (Button on the top, press and hold)
On the RS300. Set as Acess Point, Ethernet from Yellow box on RS300 to D7000 port LAN port 1 (also yellow).
*Side Note.
I have a range TP LINK extender AV600 moved its ethernet to Lan 4 on the RS300, that has just worked like magic :-)
RedThunder
May 24, 2025Tutor
So for the record.
*Side Note.
