bombero1981
Aug 29, 2024Aspirant
Nighthawk RS 700, Can't get 5 gigs out of this router
5 gig service through Frontier Fios, i get 5 gigs through Frontier Fios EERO 7 router, can't get 5 gigs out my Nighthawk RS 700 only getting 4355.78Mbpd Download and 2637.06Mbps Upload, changed ether...
Aug 29, 2024Guru - Experienced User
Are you supposed to be seeing 5Gb both UP and Down?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# ethernet adapter are you using that's connected to the back of the RS?
Armor, Smart Parental Controls or Circle, Traffic Meter.
- bombero1981Aug 29, 2024Aspirant
yes 5gigs up and down, don't know the model or brand of Frontiers ONT, will need to open their cabinet on the back side of my house, using new cat6 cable, will try suggestions.
Thank you
bombero1981
Firmware Version V1.0.7.86_2.0.82
direc cable connect from ONT to router, i disconnected Frontiers EERO 7
will disable Armor, don't have the other 2 items enabled.
Thank you
bombero1981
- FURRYe38Aug 29, 2024Guru - Experienced User
Check to see if the CAT6 cable is UTP or STP.
How far is the ONT from the RS?
i have both types of cat 6 does the same with both, ONT to RS give or take 75 to 80 feet, Frontier tech was here yesterday he tested the CAT 6 coming from ONT to RS with a meter and he said he was getting 5 gigs up and down, only markings on ONT,
Intertek
XGS-PON ONT
Model: FRX523
- ShadowMario3Aug 29, 2024Luminary
Didn't see you mention it, but can you check if QoS is enabled, and if it is, can you disable it and try a speedtest again? Might be worth it to try the speedtest from the QoS page itself (after you disable it) before trying it on your end.
that feature is disabled.
Thank you
bombero1981
- BH_CAug 29, 2024NETGEAR Expert
I would like to confirm if my understanding on the issue is correct.
- For the speed tests with RS700, did you run the speed tests (1) from the RS700's Web GUI or from the Nighthawk App? (2) from a PC connected to the RS700?
- You have disabled these functions: Armor, Smart Parental Controls, Traffic Meter, and QoS, and you still got the same results?
