bombero1981
Aug 29, 2024Aspirant
Nighthawk RS 700, Can't get 5 gigs out of this router
5 gig service through Frontier Fios, i get 5 gigs through Frontier Fios EERO 7 router, can't get 5 gigs out my Nighthawk RS 700 only getting 4355.78Mbpd Download and 2637.06Mbps Upload, changed ether...
Aug 29, 2024Guru - Experienced User
Are you supposed to be seeing 5Gb both UP and Down?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# ethernet adapter are you using that's connected to the back of the RS?
Armor, Smart Parental Controls or Circle, Traffic Meter.
bombero1981
yes 5gigs up and down, don't know the model or brand of Frontiers ONT, will need to open their cabinet on the back side of my house, using new cat6 cable, will try suggestions.
Thank you
bombero1981
