bombero1981
Aug 29, 2024Aspirant
Nighthawk RS 700, Can't get 5 gigs out of this router
5 gig service through Frontier Fios, i get 5 gigs through Frontier Fios EERO 7 router, can't get 5 gigs out my Nighthawk RS 700 only getting 4355.78Mbpd Download and 2637.06Mbps Upload, changed ether...
Aug 29, 2024Guru - Experienced User
Are you supposed to be seeing 5Gb both UP and Down?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What brand and model# ethernet adapter are you using that's connected to the back of the RS?
Armor, Smart Parental Controls or Circle, Traffic Meter.
bombero1981
Firmware Version V1.0.7.86_2.0.82
direc cable connect from ONT to router, i disconnected Frontiers EERO 7
will disable Armor, don't have the other 2 items enabled.
Thank you
bombero1981
