bombero1981
Aug 29, 2024Aspirant
Nighthawk RS 700, Can't get 5 gigs out of this router
5 gig service through Frontier Fios, i get 5 gigs through Frontier Fios EERO 7 router, can't get 5 gigs out my Nighthawk RS 700 only getting 4355.78Mbpd Download and 2637.06Mbps Upload, changed ether...
bombero1981
Firmware Version V1.0.7.86_2.0.82
direc cable connect from ONT to router, i disconnected Frontiers EERO 7
will disable Armor, don't have the other 2 items enabled.
Thank you
bombero1981
Aug 29, 2024Guru - Experienced User
Check to see if the CAT6 cable is UTP or STP.
How far is the ONT from the RS?
- bombero1981Aug 29, 2024Aspirant
i have both types of cat 6 does the same with both, ONT to RS give or take 75 to 80 feet, Frontier tech was here yesterday he tested the CAT 6 coming from ONT to RS with a meter and he said he was getting 5 gigs up and down, only markings on ONT,
Intertek
XGS-PON ONT
Model: FRX523
- FURRYe38Aug 29, 2024Guru - Experienced User
oK.
I presume this is your ONT unit?
https://duckduckgo.com/?q=xgs-pon+frx523&t=h_&ia=web
Being that far, might check into some CAT6A STP cabling to ensure good signal between the ONT and the RS.
Let us know if the suggestions mentioned change anything.
