JOATAMON
Oct 22, 2025Star
Nighthawk RS100 can't see 2.4Ghz WiFi devices
I just replaced an old Orbi with the RS100. The Orbi, and my network, were working, but the Orbi app could no longer see the router, and I wanted WiFi 7 anyhow. I set the SSID and password on the RS1...
CrimpOn
Oct 22, 2025Guru - Experienced User
Some older 2.4G WiFi devices struggle when the 2.4G network supports WiFi6 (802.11ax) Is there an option to disable 802.11ax on the 2.4G channel?
