fbeinfo
Nov 10, 2024Guide
Nighthawk Rs200 - no WIFI after Reboot - Internet via LAN ok
Hi all the problem is at a Nighthawk RS200 - The configuration iwth my provider here in Luxembourg worked fine. VLAN TAG - is used here for orange.lu now.... some fine tuning has been done and i...
- Nov 16, 2024
The problem seems to have been solved.
After a 2-hour phone call with the English-speaking support team, the problem disappeared (although this was probably a coincidence after a factory reset). The router probably assigned the IPs randomly so that there was no longer a conflict. As I have now been able to find out, it was most likely an IP conflict in the WLAN as both static and dynamic IPs are assigned in my network. However, the DHCP assignment referred to the entire address range. This most likely led to the said conflict - which then “deactivated” the WLAN - this also happened to me with competitor products. Furthermore, there was another 2 router in the network which was also configured as a router instead of an AP - but with DHCP..... switched off.
Please close the case 48659368.
Translated with DeepL.com (free version)
JasonJT
Nov 11, 2024Initiate
I'm getting the same issue on the RS200
Setup and used fine for a month, now after restart I can connect to internet fine through LAN cable, but wifi is not working. Tried many settings and no luck
fbeinfo
Nov 12, 2024Guide
Hi Jason
talked yesterday night 2 hrs to the support.
we did several tests.at the end the wifi worked after a reboot
but we don't know exactly why.....Questions:
0.1) Which Firmware do you use?
1) do you have Wifi Extenders in use - which are directly connected to your RS200?
2) If yes, are these Non-Netgear extenders?
3) do you use DHCP?
4) do you use DHCP and static addresses in the same range?
please let me know i might be able to help you
Regards
Fred
