fingercurse
Mar 23, 2025Follower
Nighthawk RS300 Wireless Router Randomly Fails Requires Power Reset
I've had this router for about a month now. Sadly, it's too late to return it to BestBuy. In the course of the month, I've had all my devices get kicked off he Wifi and they cannot get back on until...
BH_C
Mar 25, 2025NETGEAR Expert
Hi fingercurse,
Did you try these?
* disable Smart Connect, use different SSID for different band
* check if the intermittent connection issue happens only in certain band?
* if it happens on the 5GHz band, try to set the 5GHz to channel 40 and mode "Up to 1.5 Gbps", just for diagnostic purpose.
