TomX
Jan 29, 2026Aspirant
Nighthawk RS300
Hi.
Nighthawk RS300
I am having the same issue but trying a different browser does not solve the problem. Rebooting the router solves it but only temporarily. FW version is V1.0.5.22. About 20 connected devices.
Thanks.
1 Reply
What issue are you seeing?
What browsers are you using?
Happens with the Nighthawk app?
What devices do you have connected? Brand and model# please.
Is IPv6 enabled?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
