Juokelis
Dec 09, 2024Aspirant
Nighthawk RS500 IPTV
Hi! I'm trying to replace Telia LT router with the Nighthawk RS500. I'm getting internet and television from Telia LT. I've tried different setups with RS500, and the best I achieved was to get ...
Dec 09, 2024Guru - Experienced User
Id make contact with the ISP to ensure the RS can replace there equipment and ask for help on there configuration requirements.
schumaku
Dec 10, 2024Guru - Experienced User
The answer will be to deploy the ISP supplied CPE.
Netgear router "design" is stuck in the late 1990ties, still limited to bridge eg. the IPTV VLAN to a dedicated port only, not offering what virtually any CPE OEM does implement.
