Andy_1985
May 24, 2025Tutor
Nighthawk RS500 Trage download snelheid !
Ik zou 250 Mb van mijn ISP moeten krijgen en ik krijg draadloos en ook via de kabel maar maximum 90MB eruit... Kan iemand mij alstublieft helpen ?heb al vanalles geprobeerd maar niks lijkt te luk...
- May 25, 2025
You were right!!
I tested it with a new cable and now I get my full speed from my ISP!!
Thank you for the help!!
Best regards,
May 24, 2025Guru - Experienced User
Might help posting in the correct forum for your region/language. I used google translate on yours.
Usually if you're only getting 90mbps, your connection between the Rs500 and the modem/gateway its connected to is only connecting at 10/100mbps speeds and not gigabit. Try a new cable between the 2.
