Andy_1985
May 24, 2025Tutor
Nighthawk RS500 Trage download snelheid !
Ik zou 250 Mb van mijn ISP moeten krijgen en ik krijg draadloos en ook via de kabel maar maximum 90MB eruit... Kan iemand mij alstublieft helpen ?heb al vanalles geprobeerd maar niks lijkt te luk...
- May 25, 2025
You were right!!
I tested it with a new cable and now I get my full speed from my ISP!!
Thank you for the help!!
Best regards,
Andy_1985
May 24, 2025Tutor
Excuse me sir
I write now in English..
Okay I will test this, thank you very much in advance.
If it works I will let you know!
May 24, 2025Guru - Experienced User
Sorry, wasn't trying to be rude with the language comment. There's sections for multiple languages so the mods can help if needed. Not everyone uses the "google translate" option. :)
A good page that can help check the link speed is the wan/lan port statistics page.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- Andy_1985May 25, 2025Tutor
You were right!!
Best regards,
