rossowheelws
Nov 15, 2023Aspirant
NIGHTHAWK RS700
I am looking at how to connect a Nighthawk RS700 WiFi 7 router to my home broadband. My ISP is BT and I have a Home Hub 2 router which I propose to use as a modem or Access Point. I would appreciate ...
microchip8
Nov 15, 2023Master
Put the modem in Bridge Mode and use the RS700 as router. Or, use the modem/gateway as router and put the RS700 in Access Point mode.
rossowheelws
Nov 16, 2023Aspirant
Thank you for your comments.
My ISP’s modem/router does not have bridge mode. However, it is possible to turn off WiFi which may have the desired result.
- FURRYe38Nov 16, 2023Guru - Experienced User
Try option #2 as mentioned...
