range_extender
Oct 10, 2024Follower
Nighthawk RS700S short range
I just unpacked an RS700 to replace the old #Nighthawk Ax12 RAX200, which has provided a good signal throughout most of the house for many years. Range is important, which is why I bought an RS700 af...
Oct 11, 2024Guru - Experienced User
make sure you're on the latest firmware and you do a factory reset/reinstall.
If that doesn't help, exchange it.
I've seen a few posts about users c/o this same issue but I haven't seen a fix.
Makes me wonder if there's a few with sketchy chips or loose antenna's on them.
