Yonisi
Mar 19, 2025Aspirant
Nighthawk RS90 Router - I need very specific technical information
Hi, I ordered a Nighthawk RS90 Router through Amazon and the product reached the local custom office about a week ago. The custom office is asking me to fill a special form in order to pass the gove...
Mar 19, 2025Guru - Experienced User
Can look up what specs are for 2.4 and 5Ghz on a online search as these would be for both frequencies seen on any wifi router system.
Power requirements varies and is mostly kept at the mfr level.
- YonisiMar 20, 2025Aspirant
Is there a way to tell the 5GHz frequency that is associated with each of the 802.11 type?
I mean the n/ax/be etc? Is it even relevant to talk about those with regards to frequencies? I tried to find a table/explanation between the different types of 802.11 protocol and to frequencies used by each, but I only found this on Wiki:
https://en.wikipedia.org/wiki/List_of_WLAN_channels- FURRYe38Mar 20, 2025Guru - Experienced User
The modes all use same frequencies.
OK, so let's say that I need to describe to someone a kind of a "proof" that the Router using the modes n/ac/ax/be
is using the following frequency ranges?
Should I just assume: 5150MHz to 5895MHz?
