Yonisi
Mar 19, 2025Aspirant
Nighthawk RS90 Router - I need very specific technical information
Hi, I ordered a Nighthawk RS90 Router through Amazon and the product reached the local custom office about a week ago. The custom office is asking me to fill a special form in order to pass the gove...
Mar 19, 2025Guru - Experienced User
Can look up what specs are for 2.4 and 5Ghz on a online search as these would be for both frequencies seen on any wifi router system.
Power requirements varies and is mostly kept at the mfr level.
Yonisi
Mar 20, 2025Aspirant
Is there a way to tell the 5GHz frequency that is associated with each of the 802.11 type?
I mean the n/ax/be etc? Is it even relevant to talk about those with regards to frequencies? I tried to find a table/explanation between the different types of 802.11 protocol and to frequencies used by each, but I only found this on Wiki:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
- FURRYe38Mar 20, 2025Guru - Experienced User
The modes all use same frequencies.
