mikes19
Jan 16, 2026Aspirant
No devices showing
I have an Nighthawk X10 RS300 router and when I connect to it via the web on my computer, I see no devices. Anytime I click on a web menu choice that should show my connected devices, nothing shows....
- Jan 16, 2026
Tried Google and it works fine, thanks, would not have thought that should make a difference.
thanks again,
Mike
Jan 16, 2026Guru - Experienced User
What browser are you using?
Happpens with other browsers?
Try a different PC to see if issue follows?
What FW version is loaded on the router?
mikes19
I'm using Mozilla Firefox, have not tried any other browser (good thought), have only 1 Laptop but will try from another computer and the firmware is V1.0.5.22, I think the latest.
thanks,
Mike
