mikes19
Jan 16, 2026Aspirant
No devices showing
I have an Nighthawk X10 RS300 router and when I connect to it via the web on my computer, I see no devices. Anytime I click on a web menu choice that should show my connected devices, nothing shows....
- Jan 16, 2026
Tried Google and it works fine, thanks, would not have thought that should make a difference.
thanks again,
Mike
Jan 16, 2026Guru - Experienced User
What browser are you using?
Happpens with other browsers?
Try a different PC to see if issue follows?
What FW version is loaded on the router?
mikes19
Also, just noticed that the same inaccurate connection type is displayed on my Nighthawk Iphone app.
