mikes19
Jan 16, 2026Aspirant
No devices showing
I have an Nighthawk X10 RS300 router and when I connect to it via the web on my computer, I see no devices. Anytime I click on a web menu choice that should show my connected devices, nothing shows....
- Jan 16, 2026
Tried Google and it works fine, thanks, would not have thought that should make a difference.
thanks again,
Mike
mikes19
I was having a problem with connected devices not showing up when I connected to my Router via the web based computer interface, solved by a different browser connection (thanks FURRYe38) I'm now having a different problem in that I have 43 connected devices, 40 wireless (most 2.4 Ghz) and three wired. Both my Iphone Nighthawk app and my computer/web interface are both showing about 30 of my wireless devices incorrectly as wired connections.
Sorry for being a pain hoping there is another "simple" answer.
Mike
- mikes19Jan 16, 2026Aspirant
I think I solved the problem. I have an TPLInk EAP110 v3 wireless outdoor access point, with an ethernet connection to my Nighthawk Tri Band WiFi 7 R300 router. I unplugged the TPLink and rebooted my router and everything now shows the correct connection type. I don't understand why, I could have set the TPLink up incorrectly, not sure.
Mike
- FURRYe38Jan 17, 2026Guru - Experienced User
Yes a AP with a ethernet connection will change the status of devices connected to it that is seen by the RS router.
Glad you got it all working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- mikes19Jan 17, 2026Aspirant
Thanks for your input and help
Mike.
