olegeezer's avatar
Jul 21, 2024
No LAN port aggregation activation between CM3000 and RS700S
I tried to set up the LAN port aggregation between my CM3000 modem and RS700S router. I connected the two aggregation ports of the CM3000 to the aggregation ports 1 and 2 on my RS700S router using CA...
  • plemans's avatar
    Jul 21, 2024
    1. Why are you using lan port aggregation? Use the 10 gig wan port on the router and the 2.5gig port on the cm3000. You'll have better throughput and less issues with stability/latency/ping
    2. the RS700 has 2x 10gig ports. 1 for the wan side, and one for device side. The other ports are 1gig. If you're only connected to a 1 gig line, you'll max out at gigabit speeds and not multigig. Thats how the wifi can hit faster speeds than the wired devices.
