olegeezer
Jul 21, 2024Guide
No LAN port aggregation activation between CM3000 and RS700S
I tried to set up the LAN port aggregation between my CM3000 modem and RS700S router. I connected the two aggregation ports of the CM3000 to the aggregation ports 1 and 2 on my RS700S router using CA...
- Jul 21, 2024
1. Why are you using lan port aggregation? Use the 10 gig wan port on the router and the 2.5gig port on the cm3000. You'll have better throughput and less issues with stability/latency/ping
2. the RS700 has 2x 10gig ports. 1 for the wan side, and one for device side. The other ports are 1gig. If you're only connected to a 1 gig line, you'll max out at gigabit speeds and not multigig. Thats how the wifi can hit faster speeds than the wired devices.
olegeezer
Jul 21, 2024Guide
I am wanting to set up an umanaged switch with 2.5G multiple ports that I can connect to the 10G LAN port on this RS700 router. Then connect my three PCs to the ethernet switch. How would the WaveLink help do that?
ShadowMario3
Jul 21, 2024Luminary
In my previous reply, for some reason, I thought you already had a 2.5gig switch. If you are looking for one, you can get either the Netgear MS305: https://www.amazon.com/NETGEAR-Multi-Gigabit-Ethernet-Unmanaged-MS305/dp/B0BGYS7731
Or the Netgear MS308: https://www.amazon.com/NETGEAR-8-Port-2-5GB-Switch-Multi-Gigabit/dp/B0D54STHFZ
Only difference between them in how many ports you need.
- olegeezerJul 21, 2024Guide
Yes, I am looking at netgear MS308, Trendnet TEG-380, and TP--Link unmanaged switches. I want it to be simple. Just connect and go. I want the best one too. I have already spent a thousnd dollars on the modem and router and that is a discounted price.
