migsta
Nov 12, 2023Apprentice
No Nighthawk Mesh on RS700
What's up with this device - doesn't work with Nighthawk mesh. My internet router is at the latest firmware but not the other one which I'm trying to setup with Nighthawk mesh but scanning the barcode says invalid barcode and trying it manually does not work even if I hardwire it. At this price point, this is pretty expensive for a router not to work as a mesh. Is it not supported or supported yet but YET would be dumb as why release something that can't mesh. I guess that's why they have Orbi right?
Do you have two of these RS routers? Was mentioned the RS was possibly going to be MESH with another RS700.
- migstaApprentice
I have 3, was hoping to mesh them. Returning them ASAP. Doesn't work as going into the Nighthawk mesh on the app asks me to scan the barcode on setup but says invalid barcode when scanned. Trying it manually doesn't find the satellite even if I hardwire it. Not supported yet or will never be supported I guess.
I think the MESH support is still in development.
