Dummy001
Jul 05, 2026Tutor
No VPN?
Router is a new RS100. I've been all over the Advanced set up page and cannot find where to set up a VPN. I'm just starting to dabble into this and would like the router for my VPN, for now. Any idea...
Jul 05, 2026Guru - Experienced User
Dummy001 wrote:Router is a new RS100. I've been all over the Advanced set up page and cannot find where to set up a VPN. I'm just starting to dabble into this and would like the router for my VPN, for now. Any ideas where it's hidden?
The manual doesn't include any reference to that feature.
The RS200 has it - note that in all Netgear routers that have the feature, it is for remote access (a vpn server), not a VPN client that will send all your client traffic through the VPN.
- Dummy001Jul 05, 2026Tutor
So, the 100 has no vpn...ugh. must have been why it cost what it did. We're on a budget and the 100 appeared to be decent. I wish my old R6220 was more up to date. I believe it had it.
How does the Firefox VPN compare then?
Thanks for the quick response đ
