Dummy001
Jul 05, 2026Tutor
No VPN?
Router is a new RS100. I've been all over the Advanced set up page and cannot find where to set up a VPN. I'm just starting to dabble into this and would like the router for my VPN, for now. Any idea...
HappyCat
Jul 05, 2026Virtuoso
StephenB wrote:I've been all over the Advanced set up page
The RS100 appears to support two forms of VPN:
- The built in "Host mode" which allows access to the LAN from the internet, and
- A feature of the Optional Bitdefender Armor capability (which you have to pay for)
Look under Services and Security on the Product Data Sheet:
https://www.downloads.netgear.com/files/GDC/RS100/RS100_TS.pdf
Dummy001 wrote:must have been why it cost what it did
Not even the most expensive Nighthawk router includes a VPN Client feature.
- StephenBJul 05, 2026Guru - Experienced User
Where are you finding that? "Host Mode" is not in the user manual and in the datasheet either.
